stevenvalerie
- Feb 15, 2013
- 12
I just bought a non-running Waverunner. I bought it without being able to check compression and was told that the only thing that was wrong with it was the jet pump.
After tearing into it, I first discovered that the starter was toast. I opened the starter and it was so rusted I could barely pull it apart. Therefore, I still cannot check compression. However, I was able to turn the shaft coupling by hand and the engine turns easy enough. I inserted my compression gauge into each spark plug hole. I found 2 of the cylinders very hard to turn due to compression but 1 cylinder is not compressing and you can hear air leak somewhere during the compression stroke. So I assume I have little to no compression on that cylinder. I also assume that the air could only be leaking through the rings. Would the damage have to be bad for air to leak when turning by hand? Or will worn rings do that?
I do not want to put a lot of money into this project and didn't invest much when I bought it for this very reason. I would be able to rebuild this motor easily but everything seems so expensive. I am trying to figure out what the minimum is that I could get away with replacing. I have not removed the head yet to see the extent of the problem. If I find that the cylinder is clean and rings are the problem, can I get away with a top-end rebuild? How important is it to inspect the crankcase and crank in this situation? Also, how important is a pressure test in this situation? One reason I have not removed the head was so that I could do a pressure test if need be. Are the crank bearings and seals okay even though its 15 years old?
My idea would be to 1: pressure test the crank case, if it passes and the crank turns smoothly then assume all is well with crank case 2: remove heads and cylinders, replace rings, hone, reassemble with new gaskets. 3: Clean and rebuild carbs.
Am I wasting my time? I would hate to put a few hundred dollars in this and it seize after a couple of hours running.
