Im a experienced boat owner, but a first time PWC newbie. I wanted to check on the proper proceedure for winterizing the 2 stroke waveraider. I Added Stabil to fuel, rev the engine (for a few seconds)with it tilted up and blew water out the back. I took the larger hose off that runs.from the top of the exhaust elbow, to the jet pump. Attached a hose and funnel to the fitting on the exhaust elbow and poured pure antifreeze in until it ran out the back. Did this displace the water in the engine? I then fired it up for a couple of seconds and blew antifreeze out the back. Fogged the engine, and sprayed some down the cylinders, then cranked it to blow out excess. Put spark plugs back in. and removed the battery. Is there anything I missed? Im not familiar with the path the water takes on the 700 2 stroke cooling system, and want to make sure i got it right so I dont freeze it up this winter. Thanks in advance for your advise.
Dwight
Dwight
