Re: What oil do you use in your 2 stroke?
as stated earlier, you can run cheaper oil, but maintenance will need to be more diligent in the PV engines.
Make sure the oil is API TC rated!!! do not run TCW3... the 2 stroke yami`s ski and seadoo ski engines are not outboards...
fact: Castrol made BRP XPS II oil for years and now there is a new vendor.
fact: Citgo makes the 2W yamalube. despite complaints of a dirty oil, the yamalube is good stuff and can be purchased much cheaper if you shop online. The 2W id also a synth blend specifically for the cats...
true,a D plate (yamaha) is a good thing. to many have lost a cat and did not know it until further diagnosis requiring disassembly of the Cat chamber/housing.
Mystik Lubricants are also made by citgo, and a very good oil.
you can buy 2W, 2S here>
Yamalube : Oil, Outboard Motor Oil, Yamalube, Evinrude Oil, Mercury Oil, 2 Cycle Oil, Bulk Oil. Discount Online Marine Oil
and the Mystic here >
https://www.mystiklubes.com/ProductList.do
personally I`ve been running Amsoil for years in the GP and now the seapoo boat.
remember one thing, skimp on oil, use the wrong type and you`ll pay a lot more in the end...
pretty much you`ll be good with off the shelf wally world brands as long as you watch and maintain your ski/boat...
the newer 1300`s have new SS clips that secure the oil lines and they very rarely come off... I`ve also never came across a failed Mikuni oil pump... broken clock spring yes, but failed pump NO...
AMSOIL INTERCEPTOR 2-Stroke Oil
and for your own conclusions you can read all about oils here>
http://www.bobistheoilguy.com/forums/ubbthreads.php
