I have a 1995 Yamaha 701cc Superjet.... this is the issue I'm having with it.... can run it for along time just cruising around then you hit waves and it stops dead ,if you are fast enough to let off the gas it will keep going but it usually stalls dead ,then it will start right away real easy @ first but it seems that the longer you ride it, it starts to stall out when going fast and sharp turns, and gets harder to start and you seem to have to choke it or hold the throttle wide open and it will start ,if you take it to shore leave the jet ski for a few hours then try it again things seem good for awhile then problem
repeats it shelf all over...... I thank anyone for a possible solution for this issue. Please forgive me if I have posted in the wrong forum. Thanks again for any responses, Dan
