Hi All,
I have a 1999 1200 XL limited. It was working fine until I changed the battery last week. Probably a coincidence but now there is no spark.
I have tried the following:
Checked all 3 plugs- no spark at any
Unplugged and cleaned all of the plugged connections on the ski
Opened up the water proof electrical box and checked for power at all of the connections, all good up to where the power goes through what appears to be a voltage regulator?? which is bolted to the outside of the waterproof enclosure.
Checked the START/STOP switched, they appear OK. The engine winds over fine.
Is there anything I have missed, like a relay or something as there appears to be no signal to initiate spark when the starter is pushed. I am trying everything I can as it is a 5 hr drive to the nearest service agent.
Cheers
David
Cheers
David
