Im having the same problem as "steveclv". I've tried to remove the carbs but was only able to remove one bolt. I'm scared if i put additional presure on the other three bolts they will break.
1. What suggestions to get the bolts removed without breaking them.
2. What if i removed the fuel lines coming into the carbs and sprayed cleaner in each location to desolve/remove build-up obstruction(s)? Could/Would that have any value or could i damage something?
Thanks
Thanks
