fineazell1
- Mar 14, 2011
- 4
I put the sea rayder in the water yesterday after sitting in the garage for a couple of months. It fired up on the first try then died. It would not start again. It would turn over fine, just wasn't getting fire. Checked the plugs and they were black. So I replaced the plugs that night. Dropped the boat back in the water the next day and it fired up then died again. Tried to start it again but now the flywheel turns about 1 rotation and stops. I can't turn it by hand clockwise at this point. I can rotate it about 3/4 turn counter-clockwise then it won't turn any more. Then I can go back the same distance clockwise with the same result. It feels like a pressure stopping it and not a mechanical stop if that makes any sense. There is no noise other than a slight sound of air coming from somewhere as I am putting pressure (by hand) on the flywheel to turn.
Any ideas of where I need to start? I checked to see if I pulled something up into the impeller and as far as a visual inspection (of what is visible) I don't see anything.
Thanks in advance for any advice.
