DVA testing. Stator and Trigger
boerdoc1
I want to test the stator output and the trigger output on a sport jet 90
If you do not have a test harness (511-5207A) how can you test the CDM output. I have a DVA. Is there any way to do it without the harness?
Thanks
Kent
kend301
Re: DVA testing. Stator and Trigger
Yes there is , I will find the site tonight and post up the procedure later toady
boerdoc1
Thanks in advance Kend301. you can pm me if needed.
Kent
kend301
The way to do it is to use needle inserts for a DVA leads and insert them inside the rubber grommet of the wires to be tested and take readings from there . , I would personally make a harness to the specs of the test harness , much easier on the bank account .
