I have a 1994 Jet Storm with a 90HP Force/Merc engine. Bought the boat 2 years ago and have not had much success in getting it to run, better yet start reliably. (Left me on more than one occassion out on the lake!)
Here is where I am now after this seasons effort, great spark (after replacement of bad (in order): battery, spark plugs, Control Module, Voltage Regulator). Checked out the entire electric section (down to the Red stator), built a DVA adapter for my DVM and again all voltages are within spec.
Thought I was good to go as last summer I had a guy rebuild all three carbs, he said it was running fine, before he blew the electric.
Tried to start it up yesterday and could not get it run. Removed the front air intake cover and this is what I see: Gas pouring out of the carb at the bottom of the carb choke/butterfly opening. Checked the 3 carb bowls and though all 3 have small amounts of gas (not enough to be full), clearly the floats have not properly engaged to shut off the gas flow. Again checked all three floats and all appear to be working properly. I think the carbs are OK.
Moved to the fuel pump and have ordered a rebuild kit based on some links that I have read that it could be the culprit, but my question is: if it is not the fuel pump then what would cause the carbs to continue to pour gas into the carb apparently so fast as to not let the float engage and shut off the gas supply.
Thanks in advance for ANY ideas!
