Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
1996 Yamaha Wave Venture 1100 Triple
  • 1996 Yamaha Wave Venture 1100 Triple
    I just got a a 1996 Yamaha Wave Venture 1100 Triple, It has been sitting on a dock for 2 years and they said last time they had it out thay thought it had some carburetor problems. Well it had a dead battery but I hooked another one to it and it fired up instantly, althought it was on the trailer so I killed it after like 5 seconds. Waited a little while hit it again and fired right up. So I took it and backed it in the water and it fired right up, died and wouldnt start back. Today I didnt want to fire but finally it did and I had to give it gas to keep it running ran it for like 5 seconds shut it off since it was in my garage and I heard something I looked down back and it was pouring oil out by the impeller??? Do pwc's have a lower unit oil, like outboards??? Help please???
    Re: 1996 Yamaha Wave Venture 1100 Triple
    I'm not too familiar with Yamaha, but Sea Doo has gear oil in the jet pump cone. it might be that which clearly isn't a good thing.
    • #3
      Thanks, so how bad a thing is it? What will I have to do to fix it? I guess it blew a gasket or something for that to come out.
      • #4
        if that is, in fact, the issue, you take off the pump nozzle, then you can access the cone...it's probably 3 bolts that you undo to take it off to get to the gasket.
        • #5
          Ok thanks. Is this a hard job to do?
          • #6
            It's not that bad. Just be patient and if the cone doesn't come off...tap it, not BANG THE CRAP OUT OF IT.
            Here's a video i found of a sea doo one...might be a little different on your ski but it should help.
            http://www.youtube.com/watch?v=hjil9OdfsL8
            • #7
              Okay I watched the video's and they really helped thanks. I went and looked at mine and I know the oil didnt come out around the jet cone. I think it might have come out around the big part idk what to call it but it's about the same distance back and alot bigger. Is a seal the only thing that could of caused this or what else can I look or when I tear in to it? It has been sitting on a dock on a lift it's whole life. And it's not been moved in two years and the bottom was jest below the water I think or it's been splashing up on it one becase it has corrosion on it, could that have anything to do with it?
              • #8
                Is it black and like a sludge coming out of the exhaust. It is probably just water and oil mixture coming out of the exhaust. Your exhaust mixes with water to help cool it, the water itself will turn into a dark sewer like liquid by itself, especially after two years. You should run your ski on a hose (low pressure) while the ski is running and the black fuid will clear-up. Do not run it long on the hose to keep the pump bearings from heating up.
                • #9
                  I didnt know that. Maybe it is. I had just started for about 5 seconds and cut it off and heard it pouring out by the impeller area. It didnt come out the cone but about that far back. I realyy don't know I'm 17 this is my first time to have one I just got a really good deal on it.
                  • #10
                    Check out this website, Green Hulk PWC. there are Yami guys that will help you out, take your time and you will not have a problem. They will help you learn what is needed to keep and maintain your ski. That is a good stable ski and can pull skiers and tubes, good luck.
                    Also, if you hear something strange or it runs a little different, those are tell tale signs of a possible problem, get it checkout and ask questions, those who can get you answers will help you diagose future issues.
                    • #11
                      Yes it was coming out of the exhaust. It has I think a super charger on the exhaust and dual's at the end, I stuck my hand in both duals and that stuff was coated all on the inside. So once I knew it wasnt pump oil or anything I cranked and immediately it put a little more out. Since this hasnt been started in two years is it normal for it to smoke alot?
                      • #12
                        It will smoke alot at first if there is fogging oil in the cyclinder and crankcase, fogging oil is used when winterizing and or for when you ski will not be used for over 3 weeks. It protects internal metal parts from moisture and rust. The smoking should slowly reduse but not completely go away, remember there is oil in the fuel mixture so it will smoke some. You can further reduse the smoke by using some synthetic oils.
                        • #13
                          Yes I know synthetic oil's are the only way to go. I'm going to drank the gas (since idk how long it's been in there) and replace all the fuel lines and filter. I've noticed to other line's that come out of the fuel tank and go under my intake manifold were my carb's are. What are these? Because it has the line that comes out the petcock in to a filter and into the farthest carb away I guess I can fill a little fittin under there.
                          • #14
                            I believe the lines coming out of the gas tank are:
                            Main fuel line
                            One way breather line for allowing air into the tank as fuel level drops
                            Reserve fuel line
                            Over flow line that brings excess fuel, from carbs,back to the gas tank.
                            • #15
                              Originally posted by bently View Post
                              This diagram should show all of the fuel lines.
                              I can not get my diagram to upload..
                              Back to Top
