Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
welding a Aluminum crankcase?
  • welding a Aluminum crankcase?
    Have anyone try welding a Aluminum crankcase ?
    dose it work?
    video
    Alumiweld Aluminum Welding Rods
    my Johnson 150TL79C1516657
    Re: welding a Aluminum crankcase?
    dose it work?
    video
    Hey nguoi, The problem with welding aluminum with a torch or oxygen accetalyne rig.
    The flame will contain carbon. Carbon and aluminum do not like each other.
    When welding aluminum, the metal has to be cleaned. A Tig or Mig welding process would be used with pure Argon as a sheilding gas. If you want it done right so it will hold. Consult with a good welder with these skills. Hope this helps.
    • #3
      You can weld an aluminum case pretty easy. Don't go with those aluminum rods and torch though. Cofe is right. You need a TIG for aluminum. I'm not sure if MIG will work .
      • #4
        They do have a MIG welding process for Aluminum, but TIG would be you best bet. It is the best for getting a good weld. If you know anybody with a AC Hi Freq machine they can do it.
        sigpic
        1989 suncruiser 24 ft pontoon. 1979 johnson 70hp 3 cylinder
        • #5
          I have done all of the above. The rods suck, a spool gun on a mig is ok, but kinda sloppy looking, tig is the best way to go. If you pull the part and clean it up, welding it should be a cheap fix at any good weld shop.
          I have a hole in the water and a hole in the dirt that I use to put all of my money in.
