Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
br7es vs. br8es?
  • br7es vs. br8es?
    Just noticed the manual calls for BR7ES plugs, both Seadoo XP have BR8ES in them...any significant difference between the two? Whats the correct gap?
    Re: br7es vs. br8es?
    Friend has an older yamaha that calls for BR8HS, but he runs BR7HS, he says it burns more of the oil off, less fouling I presume, so it runs better longer. I'm not sure of the difference on the ES though.
    • #3
      For what ski? Year?
      "The problems that exist in the world today cannot be solved by the level of thinking that created them." -- Albert Einstein
      • #4
        If you responded to my post, it's a 95 Waverunner III.
        • #5
          You need to run the BR8HS and the correct gap is .024. I assume your ski is a 650, but the plugs and gap are the same for a 700.
          http://www.ngksparkplugs.com/part_finder/index.asp
          • #6
            It's just one heat range different, lower numbers = hotter plug (at least for NGK's like these, I think other mfg's may be different)
            Not a big difference, a hotter plug may keep it from fouling out a little better, if you were having a problem with that.
            • #7
              Hey Vikes, uhm the BR7 actually runs smoother. Also, I just added the reference to those plugs to help out Jimmytee, I'm not the one that needs the question answered it's Jimmy with the sea-doo. But the gap sounds good for everyone .
              • #8
                My bad. If its a Seadoo XP then the right plugs would be a BR8ES for the 951, 720, and 650 engines with a gap of .022 and BR7ES for the 580 engines with a gap of .022. The 2003-2005 951 DI engines need a ZFR4F-11 NGK Plug with a gap of .035.
