Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
Yamalube 2-W or 2-M? And reasoning
  • Yamalube 2-W or 2-M? And reasoning
    Ok so....
    After recently just getting back into jet ski...bit of a dilemma !
    Ski is a 2002 GP800r and I'm aware that any good TC-W3 oil will do, but prefer to use the yamalube. Problem is that after filling the tank with the synthetic 2-W oil, a jet ski yam expert has now advised against using this in preference of the 2-M oil....says that the 2-W oil is only for the skis with a Cat that needs low ash. Also said that the 2-W is a lesser grade oil and not TC-W3.
    The oil does say for use on all Yamaha jet skis, but he has a point if it's to a lower standard than the older and perhaps more lubricating 2-M.
    Anyone shed any light on this or have any further knowledge ?
    First of all, where you went wrong was to listen to a "yam expert". Second of all, all you had to do was google "Yamalube" and read what the manufacturer had to say.
    Your Owner's Manual should very clear on what you should put in your 'ski.
    2M is designed for outboards (including those that pre-mix). 2W is designed for watercraft (all of which inject the oil). Each description says what its for, and also states that it is NOT to be used visa versa. If Yamaha corporate says thats what you should use, then it must be OK. Low ash, cat conv. are legends that spread on the internet (another thing you shouldn't go by).
    The TCW versions were designed for water cooled outboard motors, and the rating was developed to provide good dissolution in gas as it hits the combustion chamber.
    You have the correct oil in your yami...
    2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
    2015 Yamaha FX Cruiser HO
    1984 Stingray SVB190SS & Mercruiser 3.0 Liter 140 & Evinrude 9.9 Kicker
    1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
    1960 Mulray 100 Dinghy, equipped with Beaver Oars
    1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
    68 Outboards: 1919-2017, representing 11 manufacturers
    Member ACBS, LBOA, AOMCI
    • #3
      Thanks Jim S.
      it just concerns me that the 2-w is a lesser spec oil. It's not even TC-W3.
      The 2-m is TC-w3 and was and probably still is used as the bench mark for the tc-w3 grade awarding basis.
      The bottle of the 2-m also says it's for PWC. It's also more expensive than the 2-w, which stand to the reasoning for the guy that advises me's argument.
      Apparently since the new type 2-w synthetic came out as a one type does all for jet skis....it wasn't considered as good a quality or have as good librication characteristics as the 2-m, which used to be widely used in both outboards and waverunners. Only problem was, when the later gpr 1300's came out they had cats in them and the tcw3 grade old oil was gumming them up.
      • #4
        I'd hate to think that these old yam 2 strokes have been so reliable for so long and gained their reputation for it....because the old oil was tried and tested. This newer more recent synthetic and low ash 2-w hasn't been around long enough to be termed as tried and tested, apparently.
        Is it possible that if these older machines (that are known for lasting) were ran on this modern version from day one....they wouldn't still be running or have the reputation ?
        Just a thought.
        • #5
          Where does it say that it is a "lesser grade"? It merely is a "different grade". Why would you put outboard motor oil in your watercraft? The spec for the 2M specifically says to not use it in a watercraft. Do you think Yami management and engineering is wrong?
          Once again, TCW is an outboard motor designation. Before that came on the scene we used any old 10W30 auto oil and the outboards ran just fine.
          Its your choice. Do as the expert tells you or do as Yamaha Motors suggests. Or buy some $3 Wallyworld oil.
          • #6
            Hi Jim
            It is a lesser grade from what I can tell. Apparently a TC-W2 grade. The 2-M is the later grade TC-W3 award.
            Also, the 2-M says for pwc too. There is even a picture of a jet ski on the bottle. Not sure what you mean.
            • #7
              TCW-3 obsoleted TCW-2. Someone can correct me if I'm wrong, but I believe TCW-2 is no longer manufactured or certified. If you find a can, its probably NOS.
              I don't know where you are getting your info. I got mine from the official Yamaha web site, not an after market seller. Yamaha states that 2M is for outboards and "it is not recommended for Watercraft". That's a quote! The 2W description states its specifically for watercraft. The current production bottle has a picture of an outboard on it.
              Anywhoot, you asked for reasoning, that's it. I always follow the manufacturer's recommendations and my owner's manual.
              OK, I give up. Use the 2M. Maybe it'll be OK.
              • #8
                Hi jim
                I've figured out what's going on.
                The UK yamalube product is completely different from your us product. In terms of not only it's labelling but also its spec and recommendations. Strange but true.
                Have a google at "yamalube uk" and look at the marine products. Specifically 2-w and 2-m.
                Strange they have different advice, packaging and even product.
                Your us website does indeed say 2-m not recommended for waverunners.
                Ours says for outboards and pwc.
                Weird.
                • #9
                  Our 2-w was apparently specifically and recently designed for waverunners only really with a catalytic converter, to stop them gumming up...not a great oil in other terms though and didn't manage the tc-w3 grade award.
