Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Electrical issues with my 2004 Yamaha FX Cruier
  • Electrical issues with my 2004 Yamaha FX Cruier
    I need help. I have a 2004 Yamaha FX Cruiser that when I push the start button all I get is a beep no multifunction display nothing. Can jump off starter relay. I am at a loss. Can anyone help...
    Not a Yam guy but on a Seadoo if I get one beep it tells me the computer did not recognize the key. I have to remove and reinstall until I get 2 beeps, then it fires right up. Look in the control box for fuses. Is your battery fully charged?
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 SeaDoo GTX
    Raw Water Pump Maintenance
    Merc Adults Only
    • #3
      The Yamaha has a lanyard not an actual key like Sea-Doo. It ran at one time had motor redone and clutch when I got it back nothing. The multifunction display doesn't even come on. Fuses are good. Battery is fully charged the ski will turn over if I bump the ignition relay with a screw driver. But if I hit the button nothing not even a click. If I hold the start button it will beep and the multifunction will come on for a second and then shut right back off.
      • #4
        Will it do the same thing if the lanyard is not connected?
        07 SeaDoo GTX
        Merc Adults Only
        • #5
          It does nothing then.
          • #6
            Bummer, was hoping there was a bad connection there. Looks like the lanyard actually connects power to everything.
            Have a look at this thread, they talk about lock mode and bad connections
            http://www.pwcforum.com/yamaha-jetsk...need-help.html
            07 SeaDoo GTX
            Merc Adults Only
