Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
No announcement yet.
Thoughts on 2004 Seadoo GTS
  • Thoughts on 2004 Seadoo GTS
    Good evening. I'm new to the PWC market having owned a few outboard boats in the past. My kids ( 6 and 8 ) were recently on a seadoo for the first time and loved it and are now bugging me to get one. In our summer park, there is a 2004 Seadoo GTS that the owner has mentioned he will be selling (with trailer) for $2000 (Canadian) but there is a catch. The owner says it is not running at peak performance hence the "cheaper" price. I have spoken with a seadoo tech who has said it "could be" fuel lines, carbs or crank shaft but hard to diagnose without seeing it but rough estimate would be $200 - $1000 to fix depending on the issue. My question for you folks is it worth taking a chance on at $2000, or possibly even a $1500 offer? Overall its in good condition except for some cracking on the seat. Because my kids are younger I'm not looking for something crazy fast or expensive. Any suggests or opinions on this model Seadoo would also be appreciated.
    Harvey
    You sure its a GTS? I'm not finding a listing for a GTS in 2004. last mention of a GTS model is in 2001, which has a 717 engine. In any case, basic "bring back to life" scenario for carbed Seadoos involves rebuilding carburetors (using OEM Mikuni kits, not aftermarket), removing old 'TEMPO' fuel lines and re-plumbing fuel system. New fuel filter and gasket for fuel water separator, new oil filter, Clean out or replace fuel selector, new wear ring. That all will set you back around U$300 and probably 4-6 hours of work. Always heard parts cost more in Canada. crankshaft is more of a "it either works or it doesn't", with the only problem you can readily identify as leaking crankshaft seals, which cause the lower end to fill with oil if the ski sits. There is a workaround involving adding a valve to the oil bath lines which will allow you to use the ski for years before having to rebuild the bottom end. The GTS are very stable skis, if anything a little underpowered with the 717 engine. Your kids would be fine on the GTS with a 717.
    1988 Stingray 176 SVB with Mercruiser 3.0L (181 CID) - The Ghostrider
    1995 Seadoo SPX 657x Rotax
    • #3
      Thank you for the reply. I have posted a picture. It is definatly a GTS but its entirey possible that either the owner or I have got the year wrong. Parts for everything cost more in Canada, as does labour. I plan on doing a compression test on the ski this weekend if the owner around which will help anser some questions for me. I'm not afraid to put a little money into something if I can get it for a decent price. I just don't want to buy somebody else headache.
      Harvey
      • #4
        For the record, that looks like a 2001 GTS. Still has the 717 RAVE dual carb engine. A little underpowered, but would be stable and good family ski.
        -E
        • #5
          717 didn't have RAVE valving. The 787 and 951 did, but the 720 was your typical rotax engine.
          1998 Wellcraft Eclipse 2000 SS (5.7 VP/SX-C1)
          1991 Kawasaki 550SX
          1990 Kawasaki 650SX
          Two Kayaks, 1 tandem, one single
          ISO another standup
          • #6
            -E
            Just to be clear; the 717 isn't a RAVE (Rotax Adjustable Variable Exhaust) engine. At least not stock from Sea Doo. Rotary valve, yes. RAVE, no.
            eavega, I see you have a Stingray! I've got a 2004 Stingray 200LX with the carbed 5.0GL-E, 220hp Volvo Penta engine. We love it!
            2004 Stingray 200LX, Volvo 5.0GL
            1973 Sanger Runnerbottom, V-drive, BBC
            1972 Stevens Flatbottom, project boat
            1997 Yamaha GP1200
            1994 Yamaha WaveRaider
            2013 Yamaha VXR
            • #7
              slag just beat me to it !
              1997 Yamaha GP1200
              2013 Yamaha VXR
              • #8
                Sorry, all. Meant Rotax, not RAVE. Got RAVE on the brain with my own 96 GTX...
                My Stingray is old, but reliable. Mercruiser 181 carbed engine. Was going to upgrade this year but got into seadoos instead!
                • #9
                  We had one just like it. "Not running at peak performance" is what I would have said about mine as well.....
                  Personally, I wouldn't touch it at any price. It could be a money pit, as well as need repairs all the time. The ski is old.
                  When we switched to a 4-stroke it was like night and day. Now we use it all the time and don't have problems.
                  Just my opinion...
                  2017 Boston Whaler 150 Montauk & Mercury 60 ELPT Command Thrust & Merc 3.5 Kicker
                  2015 Yamaha FX Cruiser HO
                  1984 Stingray SVB190SS & Mercruiser 3.0 Liter 140 & Evinrude 9.9 Kicker
                  1964 Sea Nymph 14R & 1970 Evinrude Sportwin 9.5
                  1960 Mulray 100 Dinghy, equipped with Beaver Oars
                  1952 Lyman 15' Mid Steer & Evinrude Big Twin 25
                  68 Outboards: 1919-2017, representing 11 manufacturers
                  Member ACBS, LBOA, AOMCI
