sptjet90Reflexx
- May 28, 2011
- 383
I have a xp with 787 motor blowing oil into the cylinders.. From what I understand this is caused from a blown crank seal. I also read about a mod you can do to rig it up..
I took the oil line that comes from the oil bottle to the starboard side of the block, and unhooked it. with a male to male fitting I looped it with the port side. I believe this is the correct way to do it?
How long should it take to blow all the oil out of the cylinders?
I just want it to last a little longer.
