Offroadgalore
- Jan 13, 2016
- 9
It was running great! We beached it, the back end was pushed into shore do to waves. Should of double anchored. After that we went tubing. While tubing, engine cut to half power. I killed it, waited five min and she started right up. Then it did the same thing. I limped it back to the dock and it got worse and worse. It died 200ft before the dock. Back at the dock it fired right up. Took it home and it fired right up with water hooked up and idilled for ten min. I'm thinking overheated due to clogged water cooling line from beaching it. Mind you I have no working alarm. Or its a fuel problem. I was thinking it was the anti siphon valve because it takes fuel at the gas station really slowly. Vent problem? So I took out the fuel line connection and there was no asv..? There is a vent line attached to the front of the tank but I've yet to reach it. It runs separately to an exterior vent by the gas cap. When I blow into the vent air comes out of the fuel line (currently unattached). I also checked for water in fuel, none in water fuel filter, replaced it and fuel filter anyway. Help please
