Hello all, I have a '89 mariner magnum II 150hp outboard. The motor was in pieces when I got it and just had the entire thing rebuilt. The only thing I was missing was the prop. I ordered a mercury 21p acording to the prop finder. My issue is... should the prop fit inside the Hub on the lower unit or be the same diameter? I'm not even sure it's touching the thrust washer.
