Hello all, love the forum and the shared knowledge.
I just got a new triple tube pontoon boat and having problems getting the right prop. Dealer and suzuki says this motor runs better with the larger props on pontoons.
The boat:
27ft Avalon Pontoon, triple tube
The motor:
2015 Suzuki DF175 4 stroke
(designed operating rpm max of about 6100 rpm)
Boat and motor, dry weight is about 3500 lbs.
It came with a 3 SS blade, 16 x 20 prop....but WOT (all readings trimmed out, speeds on GPS) was 29mph @ 5000 RPM.
Swapped out for a 3 SS blade, 15-1/2 x 17 prop, and now i get 26mph @ 5000 RPM and WOT 34mph @ 6200 RPM.
(all above readings with about 1/2 tank fuel with med load of 3 persons)
Where should i go from here?? I am OK with the top speed, but would like to have a better, more economical cruise speed....something like 25 @ 4000 RPM or so.....
Any suggestions, here are my basic options...staying with Suzuki props. Dealer has been very friendly and will still let me try another prop.....no charge.
15-1/4 x 19
15 x 21
16 x 17
16 x 18-1/12
I am leaning toward the 16 x 17 but dealer thinks i will loose some WOT speed?
Thanks, any suggestions or thoughts are appreciated.
**Yes i have tried looking at some of the online prop calculator websites and either i'm not fully understanding or dont know how to compare my results***
The boat:
The motor:
15-1/4 x 19
15 x 21
16 x 17
16 x 18-1/12
