I’ve got a rev4, a mirage+, and an enertia. My boat is a foot shorter and maybe weighs 300-400 lbs less than yours due to mine being a 4.3.
my enertia mostly stays on the shelf. This summer I’ve been running the rev4 a lot even though it’s not my favorite prop. It’s an excellent stern lifting prop that allows a lot of trim adjustment on the outdrive. I’m on the Chesapeake bay which can get very choppy so it’s nice to be able to really force the nose down which the rev4 does well.
if I could always run in smoother conditions I’d use my mirage plus. The mirage lifts the bow a lot. It will not blow out at all. The problem with the bow lift is that it’s great for going fast, but when it gets choppy (and that’s guaranteed out here) it’s hard to force the bow down.
The question i have is are you trying to improve holeshot to minimize the time the time the bow is pointing up in the air? Because on shorter boats, the mirage will make the bow reach for the stars.
If you shop around, you can get some Bennett trim tabs for not much more than that prop. They can get you on plane faster without the loss of top end performance like you’d have with a lower pitch prop.
Did you ever determine your gear ratio? It sounds like you’ve got 1.47 gearing. The speeds you’ve attained aren’t really possible with 1.62 gearing because you would have negative slip, which definitely isn’t possible.
50mph and a 1.47 ratio puts you at 8.5% slip which is possible with a rev4.
Make sure you get the correct hub kit for the rev4. It’s a very heavy prop. The hub kit will contain an extra bushing to provide a bit more support. It’s supposed to help reduce the stress of surfacing on high mounted drives. On an alpha1, it makes it shift into gear easier.
No. Look for 835257K6 (mercury) or 835257Q6 (Quicksilver). This kit contains a “forward bushing” 856163Q1, and supposedly a hardened thrust washer. Honestly, you can buy just the forward bushing and insert it into the standard hub kit you’ve already got. You’re also supposed to torque it down to 90-100lb-ft but it’s not really necessary. The standard torque rating is fine. That forward bushing improves the shift feel on any prop so I use it with all of mine.
HI
just reading this post is fascinating to me. Must have missed it first time.
Not one for doubting you AK, but it doesn’t make total sense to me.
Mate you sure you have a 1.62 ratio ? The numbers seem crazy.
More than that. If you are now thinking of a 17” (all be it a big diameter rev 4), you will be crazy under propped at that ratio.
I have a similar performance hull (perhaps a little more tweaked towards performance maybe) and a 5.0 mpi with cam and exhausts, all be it (for all its worth. Not sure it’s worth much as the exhausts only make a slight difference at wot and cost load on the engine via alternator to keep them open. The cam is likely only efficient at wot because the fuelling isn’t well suited down the rpm) the boat is about 1400 kgs. But she has a 1.47 ratio.
Anyway. Any 19” of any sort prop will easily hit the limiter at 5150 rpm in seconds. A 21” laser 2 and even and enertia...also a ballistic will also occasionally hit the limiter if running light with a clean hull at start of season. Best she has ever ran was about 66.7 mph gps but usually about 64/65 with gear (or bow seats even haha) on board.
If you have a fast hull and the 5.0 mpi with a 1.62...surely to god a 17” will be rocket ship out the hole but will hit the limiter in a couple of seconds. Will be so inefficient too.
Quick update. Boat is running good. Turned 4900 rpms at 51 mph per gps. Fuel tank full, Bimini up, wife and two kids up in the bow.
Assuming the reman Merc out drive isn't miss marked with incorrect gears and is really 1.62, this hill with a 15 degrees deadrise is running 51 mph with. 3 blade 19p mirage prop.
what other info do you all need?
That’s actually very good. If you plug your data into a prop slip calculator, you’re at 6.25% slip. That’s about what I see on my boat which is 19.5’ and uses a 21p mirage plus. I’ve got 1.84 gearing and a 4.3. I see 49mph running by myself.Quick update. Boat is running good. Turned 4900 rpms at 51 mph per gps. Fuel tank full, Bimini up, wife and two kids up in the bow.
As far as 19p props go, with your current ratio, and rpm limit of 4900, the maximum theoretical top speed you can see is 54mph. And that assumes a 0% slip which isn’t really possible. What is the redline on that engine? 4800? 5000?
