How can I tell if my prop is spun. I've taken prop off the pin is intact and everything looks good. However when I try to excellerate it jumps . Could it be that it is not going all the way in forward as I have had tgat problem before had to adjust tge shifter link abd have replaced the copper coupling tgat holds tge shifter together as I noticed it was commingg apart when I shifted into forward. Anny way I haven't been bsck on water since putting tge new copper piece on and adjusting to where it goes all tge way in forward and reverse with out coming apart. So any answers would be appreciated thanks.
