The Chrysler/Force Prop thread: 85-150 (thru 1994)
SkiDad
Since ski season is about done up North, I decided to test all my props and put some stats out. These are all with a light load of approx 2200 lbs total with a Force 125 (single exhaust). I'm into water sports so I'm propped for that. Obviously everyone's setup is different but this will give you an idea of how these props compare. I'm hoping it will help someone else. Please feel free to add to this thread with your prop findings.
The 15p Turning Point hustler is a progressive pitch prop with a ton of cupping and a lot of blade area and it runs like a 17p - notice how the speeds are dead on with my 17p Stainless. But the 15p hustler out accelerated the 17p stainless and is smoother overall but has noticeably more bow lift. The Turning point has a plastic ring that needs to be removed to fit the Chrysler style gear case. Also you need to remove the anode behind the prop.
These are listed in order of acceleration.
Michigan
Michigan
Turning Point
Michigan
SST
Alum (no cup)
Alum
SST
73007
72055
21431511
SSC-317-ii-c
13-3/4 x 15
13-1/8 x 15
13-3/4 x 15
13-1/4 x 17
3500
21
19
25
25
4000
26
24
29
29
4500
29
28
32
32
5000
32
31
35
35
WOT
36
37
38
38
5500
5800
5400
5250
SkiDad
Here is a chart I made to simplify things - iboats carries the aluminum props. If you want SST you most likely have to look on ebay or craigslist for one.
I noticed that most Force engines will run good with a 17p prop - maybe 15 is needed for the serious slalom skier or heavy boat load. I left out the 21 pitch b/c I can't see too many boats being able to use that pitch. Prop your boat so you are running at 5000-5500 RPM at full throttle.
The later thru hub props will work with single exhaust no problem, you just can't do the reverse.
SizeMaterialCuppedMichiganAKANoteSingle ExhuastDual Exhaust
14 x 13AL 072054 discontinuedx
13-1/8 x 15AL 072055 availablex
13-1/4 x 17AL 072107 availablex
13 x 19AL 072108 availablex
13-3/4 x 15SSTx073002SSC-315-II-Cdiscontinuedx
13-1/4 x 17SSTx073003SSC-317-II-Cdiscontinuedx
13 x 19SSTx073004SSC-319-II-Cdiscontinuedx
13-1/2 x 15ALx071035 availablexx
13-1/2 x 15AL 072127 availablexx
13-1/2 x 17ALx071036 availablexx
13-1/2 x 17AL 072128 availablexx
13 x 19ALx071037 availablexx
13 x 19AL 072129 availablexx
13-3/4 x 15SSTx073007 discontinuedxx
13-1/4 x 17SSTx073008 discontinuedxx
13 x 19SSTx073009 discontinuedxx
These props will also fit if you take the anode behind the prop off and remove the plastic ring from the prop: Michigan Vortex, Turning Point Hustler.
I haven't verified but I think the Michigan Apollo SST is the same way with the plastic ring.
