Volvo SX, correct thrust washer for SS prop?
bunker108
I am running an aluminum 4 blade Solas 19P and a factory aluminum 21P. Both use the same thrust washer. I have an old stainless 19P that came off a Cobra Drive that I had rehubbed for my 19 spline SX. It seems like the thrust washer is too thick as there are no splines sticking through the hub so I can't key the splined washer.
Does anyone know if there is a thinner thrust washer I can order specific for SS
I would like to try the three blade stainless on this boat. Thanks!
