5.0 push a 21 pitch prop?
chartersj
Good day, I have a 20ft searay with a carb 5.0 and 1.65 gear ratio, runnning a chipped 14x19 pitch and was wondering if a quicksilver laser 11, 21 pitch would be too much for my boat? I get 46mph right now but my tach isnt spot on
might be a bit much. my 19' searay had a 15x19 solas and I could hit 50. I tried a 21 pitch and the motor fell on its face.
ihearth2o
Might want to get that tach looked at and find a good prop shop first. Take some readings then post back up with your performance goals and will probably get better help. Good luck.
mcalistor
I use a 21" on a 19' Four Winns Sundowner with no problems. Same engine setup as you. I tried a 23 for the heck of it and it wouldn't pass 4500 rpm and lost a couple mph. I didn't notice much difference in top speed between the 19 and 21, so now I just stick with the 19".
SkiDad
the 21 will work OK but it might put your rpm at the low end of the range like others have mentioned. My neighbor had a 21' SeaRay about 3500 lbs with 5.0/260hp and he ran a 21 and it was slow to plane - I always thought a 19 would have been better.
chartersj
I figured i might be able to get away with a 21 where i just added smart tabs that makes the boat effortless to get up on plane now
old islander
I have a 19' searay 190 with the 898 5.0. When I bought the boat it had a generic 21 pitch stainless prop on it. Ran at 44MPH on GPS at 4100 rpm. It also came with a well chewed 19pitch aluminum prop as a spare. One day I swapped them. The 21 was better out of the hole, but the 19 ran 47MPH at 4300 rpm. I bought a new 19 and never looked back.
