No Title
Do not rely on a plastic prop wrench. Hit or miss stripping them when removing prop nuts.
If you have one that's fine, and the merc style is helpful for lifting tangs, or tightening in a pinch or rough water...but, have a dedicated breaker bar, with 1 1/16" socket, kept in boat.
Crescent wrenches can't reach many prop nuts.
I'm sure HF will have an inexpensive breaker bar and you can drill a hole near the end for a tether, if your off shore, or the following tool is similar to what we use on water/portable.
RAM Mount Aluminum Pro-Pull 6-in-1 Prop Nut Wrench (includes lanyard)
Item# PPF-108A about $25
Product Description:
Aluminum 6-in-1 Outboard and Stern-Drive Propeller Nut Wrench
PRO-PULL Outboard and Stern-Drive 6 in 1 propeller wrench is made of solid Nibral or Marine Grade Aluminum with six tools all in one easy to use handle. It will remove and install propeller nuts, cotter pins and propeller nut keepers on the following Outboard engines:
1. Mercury 75hp & up
2. OMC 60hp & up
3. Suzuki 55hp & up
4. Mariner 75hp & up
5. Yamaha 55hp & up
It will also work on all Stern-Drive engines made by: Mercury, OMC, Suzuki, Mariner, Yamaha and many others with either a 1 1/16" or 1 1/4" propeller nut. This tool comes packaged with a safety wrist strap to prevent toollose if accidentally dropped overboard.
