I have a '99 Albemarle 242 center console. It had a Volvo Penta 5.0 GXI throttle body engine and would turn around 5000 RPM at WOT. This was paired with a Volvo Penta duoprop outdrive with a 1.95 ratio. The props are VP also and are SS F4's. Being VP, nothing gives you the pitch of the prop, just their designations.
So, I installed a new Mercury 350 Mag Bravo carbureted engine paired with the same outdrive and props. My WOT is now 4000 RPM. The stated WOT for this engine is 4400-4800. I only have about 4 hours on the engine so it has not been broken in yet. On muffs with no load the engine will reach 4800 RPM but in the water only 4000. This tells me that the props should be reduced in pitch to increase the engine RPMs. My problem with this is not understanding how you can install a more powerful engine with everything else remaining constant and it not being able to spin the props up to 4800 RPM.
The mechanic who did the work said I would not have to reprop with the new engine. Now, he says I should reprop. Can anyone explain what is happening in my setup that would cause this anomaly?
