5280glastron
- May 12, 2014
- 6
I've been all over the web and these forums trying to find some comparison points for my boat, engine and altitude for prop selection this winter. I wanted to share my results after a few test runs and 2 prop variations so other's could reference my experiences.
I also have a question that's been really bugging me, that I'm hoping for feedback on as well.
I bought a 2001 Glastron 195 this in January. I live in Denver, and purchased the boat from a guy in Pueblo who took the boat only to that lake. Pueblo is at a lower elevation 3000ish if I remember right. He had a bit chewed up 3 blade aluminum prop on it that was a 19" pitch. I knew from experience that this was probably more prop pitch than the boat needed even at that elevation, especially for my usage (slalom skiing).
Elevation at my local lakes is a mile high (5280 ft.) so if I wanted good acceleration for skiing here, I'd need to go down in prop pitch. I wanted to test out the existing prop on a local lake to get WOT range with the prop (despite the fact it was already a bit chewed up from hitting something in reverse, causing extreme cupping on the trailing edge). I got it on the lake in March (yes, somehow there was open water here in Denver in March, although only at the smaller local lake Cherry Creek).
My test day results were:
WOT 4000-4100 (trimming to the absolute max before cavitating then returning the trim just beneath the water) and I managed to get the boat to 41-42 MPH (GPS). (300lbs of gear on boat with full tank)
I knew the bad prop was having some impact, most likely on the max MPH was my impression. So I ended up buying a Solas HR Titan 4 blade 15" pitch.
I just got back from the lake test of the new prop and this is where my results have me wondering a few things. The lake test results got interesting.
WOT 4300-4400 (the minimum Max RPM for this engine) and I got up to 39-40 MPH (GPS). (500lbs of gear on boat with slightly less fuel 85-90% full).
So, I added some weight and increased my RPM by 300-400 but why so little?? The previous prop was 19" and a RPM change per one inch of pitch change should be 100-200 RPM so I really suspected that I might be over revving at 4800-5000 RPM.
I've done some prop slip calculations too, and these have me even more confused. For example:
Prop Slip Calculator | Propellers | Mercury Racing
Pitch: 15
Ratio: 1.6
RPM: 4400
Speed: 39
Slip: 0%
So somehow I'm achieving 0% slip? That's not possible. So with the cupping on the HR Titan, I adjusted pitch to 16 to account for this supposed impact of cupping and it still says my slip is 6% that seems impossibly low.
Am I crazy or does is my RPM gauge lying to me? If I was at 4800 RPM in reality, that would seem more likely as the slip goes to 8% and with cupping and possible 100-200 RPM range that put me at 10-15% slip that seems to be the more accurate range for a 4 blade.
Any thoughts? The boat only weights from 2250 - 2500 empty so it's lightweight but Is it even remotely possible I'm getting 0%-6% slip as the raw numbers indicate?
Pitch: 15
Ratio: 1.6
RPM: 4400
Speed: 39
Slip: 0%
