I have recently purchased an 18ft older model Grumman pontoon. It has a 2005 mercury 50hp 2 stroke with an 11 pitch black max prop. I noticed on the water im running 5600 rpm at 3/4 throttle. I max out at around 6400 rpm at full throttle but see no speed increase or added performance , just a louder motor. I have been told that this model engine has a ideal WOT of between 5200 and 5500 rpm. When doing the ideal prop quiz on mercury website it recommends the prop I have now with the same or lower pitch but everything I read indicates I need I higher pitch prop to lower my WOT rpm. Any suggestions??
