Garrard slab
- Mar 20, 2014
- 2
Hey all! Long time boater, but new member. I recently purchased a 1987 15 ft bassmaster brand bass boat with a 1985 50 hp johnson. The boat is fiberglass, and weighs 800-900 pounds. The outboard runs well and is mounted on a 6 inch setback cmc power tilt and trim. The current prop is an omc aluminum 11 3/4 x 17. The engine is mounted as high as possible with the cavitation plate slightly above the bottom of the boat. With me (190 pounds), six gallons of gas, full livewell, I got 33 mph at 5550-5600 rpms. I have very little trim before prop blows out, also a lot of ventilation in turns. I have very little lift, especially in the bow. Speed is gps and rpms are on tiny tach. My current prop is chewed up a little, so I will be buying a new one. My holeshot is pretty slow. I am considering a 12 1/4 x 15 hustler aluminum or same size in a stiletto or turbo. Any advice? Thanks!
