brooksville_rebel
- Aug 12, 2011
- 240
I have to change my prop since I bounced off the sand and cracked it.
I have this grease sitting in my shed.
Mobil/Synthetic grease (102481) | Lubricant/Grease | AutoZone.com
Mobil 1 Synthetic Grease.
Mobil 1 Synthetic Grease provides excellent protection against rust, corrosion and water washout. It s suited for wheel bearings, ball joint suspensions, steering linkages, and king pin and chassis lube points.
Excellent resistance to rust and corrosion
Good shock loading protection
Excellent resistance to water washout
Outstanding lubrication over a wide temperature range
Can I use that or should I get something that is says its propeller grease ?
Thanks
Mark
Thanks
Mark
