PETE BUTZEN
- Feb 27, 2010
- 58
Can some one tell me the differance between stiletto / laser II . . Stainless Thanks Pete
Did anyone notice that the slip is about 30% with that prop?
A Solas 17 pitch aluminum prop would do better than that.
4750-5250 is your WOT rpm range
Tail_Gunner;4487762.It should be noted that a Alum Solas will not perform with a Stiletto f[/QUOTE said:You're reading too much into my remark. I said that a Solas aluminum would do better than 30% slip. That's a fact.
And my experience is that the Solas would run right beside the S brand prop; right up to top speed, when the S brand would have probably a 1 mph advantage.
His prop has high slip because it's "stalling" from too much pitch, rake, and cup. It's actually the wrong design for that boat.
A good prop for that boat would be a Mercury vengeance type prop, or a Solas New Saturn.
