Jesterarts
- Jan 11, 2012
- 27
Hey all,
I installed a new 21" SS prop on my 16 foot, Pride Panther boat that is powered by an 1987 Evinrude.
I took the boat out the other day and discovered that if I try to take off any much more that about 1/2 throttle, The revs jump up high and the boat doesn't gain much speed.
If on the other hand, I accelerate at a lower throttle until I get to about 20mph and then floor it, the acceleration is brutal and she shoots up to 45-50mph in slightly choppy water.
Once thing I did notice, is this prop doesn't seen to be sitting as deep in the gearcase sleeve as my last one. So I am thinking the thrust washer might be too thick and the result is exhaust escaping between the prop and the gearcase causing ventilation?
I had a 19" prop on the boat before and I did not experience the issue.
The motor is mounted correctly, with the cavitation plate just a whisper lower than the keel.
Please let me know your thoughts.
Thanks in advance.
Thanks in advance.
