Re: Cavitation trouble
Cupped props are really designed to eliminate ventilation, not cavitation which is the sucking in of surface air just above the propeller and the plate above the prop is aptly named "anti ventilation plate" for that reason. Cavitation is another problem of a different nature.
If you want to go fast you need to have your engine high on the transom and a prop designed to run that way. You also want to trim your lower unit out away from the boat as far as you can to help to get the bow up, reduce wetted area thus reducing drag and improving top end performance. Sometimes a jack plate is necessary to get the prop high enough and far enough behind the boat to accomplish the goal. A prop designed for such service is a must and many are out there. While you are at it, if running a 2 cycle engine, they love the rpms so run it at or above (I do, have been for 20 or so years) the recommended full throttle rpms.
The "big guns" on the site, who have apparently retired and were heavy in racing and running fast and all, said toget your "setup fixed" then get the right prop.
Mark
