Re: Stainless Steel Propeller "Help"
Whatever we tell you is speculation, maybe educated speculation but speculation none-the-less. The only way you will know that you have the right match is to run it. All SS props are not alike. All SS props of a mfgr. are not alike. All SS props do not perform the same on a given engine or on a given boat. Any prop performs differently under different conditions of operation and weather.
Get cozy with a prop shop. Do the lend lease thing and test before you buy. Just remember, you are testing, not spending the week on vacation. You must return the prop in original condition for the shop to take it back and let you try another......they are going to have to sell your return to someone else as a new prop. You will pay extra for the service, $100 is not out of line, but if you want it right, this is the only way you are going to get there.
Course once you get this new prop on your boat, you need to know how to run it which is as important as the prop itself! All SS props don't run the same. All....................
Good luck,
Mark
