rookie456
- Aug 25, 2011
- 81
I bought a used 1980 80hp merc. I cannot get the prop off. I have been soaking it with pb blaster, and using a modified wheel puller with chain and hooks around the blades. Today I bought a hydraulic gear puller from harbor freight, hooked it up to the chains, started pumping the handle and the puller wouldnt work right, broken right out of the box. It would allow one pump pressure, but it would release the pressure when i pumped the handle up. needless to say I am taking it back, and exchanging it for one that works. my question is that on the one pump of pressure, the prop would move, but the hub stayed. I am wondering what holds the prop to the hub, and am i going to wind up pulling the prop and the hub will be stuck to the shaft. The prop does not have a name on it, just numbers. 48 72762 a4 19p
