hi all
I have a bayliner 2850 command bridge 5.7 engine and 280 (recon leg). I checked the drive and its def right one 1.62 to 1
I have a 16 x 13 prop which I an told is the right prop for that boat. there is one guy that says hes got a 16 x 15 prop about 300hp and he can do about 30 knots. where the people with the 16 x 13 can do about 20 +
my problem is I can only get 10 knots at 4300 rpm but that's only about half throttle the engine doesn't seam to be working hard. Before I go out and spend a lot of money on a bigger prop I though I ask what you guys think
thanks
andrew
thanks
andrew
