Are there any options for a higher thrust prop for this motor. I am pushing a 2200lb boat with the 9.5 and burn about 6 gallons of gas in 4.5 hours in 2 foot waves. Sounds like a lot of gas, but we were running the motor at maybe 2/3 throttle.
This is a short shaft and set back on a kicker drop-mount which allows the prop to be at or just below the bottom of the boat about 2 feet away. Maybe I need it even lower ?
If that is the case, I need to put a long shaft on this boat.
