SeLaOffshore
- Aug 15, 2013
- 11
Prop selection is driving me nuts! I’m just about done converting my 1995 Proline 240s (24 ft hull - 3,600 lbs) from a single 2003 Merc - 225hp Optimax to twin 2003 Merc – 225hp Optimax. The single engine was propped with a 4 blade – 14.75(diameter) 17 pitch prop. Maxed out ~5,200 RPMs and 47 Mph. Cruise speed was 32-34 mph @ 4,000 rpms consuming a tad over 10gph.
Everything I have read says I should increase the pitch on the props to take full advantage of the twins – for speed and efficiency. So I consulted with Powertech Props and they recommended a pair of props that will just about require a 2nd mortgage on the house – priced at $710 ea!
I do believe stainless is the only way to go, but I’m trying to be real about this and would really appreciate some reasonable advice on how to distinguish my optimum choice where fuel efficiency for long runs and returning home on 1 engine are my highest priorities – 3 or 4 blade, 19 or 21in pitch, cup or no cup?
