Re: 50 hp Mercury prop Question
Before venturing into wild guessing selecting other pitch from the one Factory delivered, you must go for a wot spin as normally loaded and check max achieved rpm on that boat with 50 HP engine to know if under or over propped. Then can select the best prop pitch to optimize boat engine performance. If it's not a center console with tach, you could install an induction tach to test. Get wot rpm Factory parameters stated for that engine to know if inside them.
Happy Boating
