Re: Can props that have the rubber filled hubs be repaired when they fail by spinning
You almost buy a hub kit at your local boat shop and install a new one yourself. It's not hard to do . And you should always have one extra hub assembly on your boat for just incase it happens aga
Also, they are only about 35.00 at most. Very easy to put in. Just make sure you use pjenty of grease when you assemble the prop back on your boat.
