I have an 2002 Eliminator skier 215 or sometimes called Eagle 215, It is 21.5' long. Powered by a Volvo 7.4GI. Rated at 310 HP It has a Volvo duo Prop outdrive with a 1.95 gear ratio. It has polished stainless steel "F8" propellers on it. Boat runs great. Has only 160 hours on it. The problem is it only revs up to 3900 rpm at WOT. Top speed after trimming out and a good 60 seconds of build up is 50 mph. The motor is rated at 4600 WOT. Pulls the same top speed and hole shot ( which will pull a skier up no problem) whether there is 2 people in the boat or 5 people.
I am trying to maximize performance by getting closer to that WOT rating of 4600 rpm. I think I need a smaller prop. But they are very expensive so I need to get some sort of recommendation. Does anyone out there have a boat of similar size and power train. If so , What size props are you running. I was thinking of going with "F6". That is 2 sizes smaller.
Thanks for any input in advance
