This may help you:
Boat is 20ft Sea Ray bowrider with Merc 350 260 hp V8
1st choice:
Michigan Wheel Appollo 4 blade stainless 14 3/8 x 18. #993204
Backup:
Michigan Wheel Vortex 3 blade 14.5 x 19 Aluminum. #992004
More info, had some more time to go test and swap props while on the water so all these numbers were taken within 20 mins of each other. 85 and sunny out, little to no wind, no chop, only ripples, all MPH # are gps. Drive was trimmed to the same setting according gauge, probably 75% of all the way in. Used that position for both prop tests. Although it was just me and 1/2 tank of fuel, I would expect these numbers to have a greater difference in favor of the 4 blade when 4-6 adults + cooler is on board.
WOT: 45mph @ 4350rpm with 4 blade. Plane in 5 seconds @23 mph. Michigan Wheel Appollo 4 blade stainless 14 3/8 x 18. #993204
44mph @ 4500rpm with 3 blade. Plane in 7 seconds @ 25 mph. Michigan Wheel Vortex 3 blade 14.5 x 19 Aluminum. #992004
Both props are in perfect condition with no dents, dings, ect. Both using the XHS hub system.
Plaining numbers were taken with average of 3 passes each time idling in forward gear to slam forward throttle.
I was shocked that the 4 blade was faster out of the hole and on the top end.
