Pony
- Jun 27, 2004
- 4,355
Recently purchased a new to me 2005 Lowe Fishing Machine 175s (17.5ft long w/ 92" beam). On it is mounted a 115hp Mercury Optimax of the same year. Current prop is 19 pitch. I assume I should be at 5600-5700 rpm WOT....
I was finally able to take it out on a larger lake today where I could open it up and test it out. With my dad and myself in the boat along with 3/4 tank of fuel (full is 27 gallons) I was able to get 5400rpm when trimmed out. If I stayed trimmed down I was more like 4100-4200. GPS speed was 36mph.
Is this running as efficiently as I can run it? Should I have to trim out to get max RPM? Should I try and get that extra couple hundred rpm? and finally is 36mph decent for that set up??
The prop on there is aluminum....what would I see with a SS??
