craze1cars
- Dec 26, 2004
- 1,822
Just picked up a new-to-me Landau 170 Bass boat (it's kinda like a Bass Tracker or Alumacraft Mod-V, all welded aluminum, rated to 75hp). It has a 2000 Johnson 50 hp, which my my understanding has a 2.42 ratio and an operating range of 4,500 to 5,500. Current prop is unknown aluminum (I believe factory original), 12 1/4 x 15 pitch. It's a little bit chewed up, but not bad. I'm gonna buy a prop and relegate this one to spare duty.
I just got back from a top speed run with my typical load, perfectly trimmed I got exactly 5,500 rpm at 24 mph (boat speedo...forgot my GPS). Based on slip calculator I used, that works out to 26% slip. Ungood. Seems slower than I expected it to be.
Obviously I want to improve this. Stainless is my most likely choice, but I'm open to another aluminum if someone has a suggestion. But which style/brand, and what pitch? I'd like to target a slightly lower rpm, just so I'm not flirting with the max all the time...maybe 5250-ish in a perfect world? I'm thinking about trying a 16 or 17 in a stainless. Not sure the motor will push it well enough...maybe it will.
What say you?
Does anyone got a good educated guess/suggestion for what I should buy and/or try???
Thankyaberrymuch!!!
What say you?
Thankyaberrymuch!!!
