Hey all. Just got my first 17' F/S boat with a 150 xr2. The previous owner had a 24 pitch 3 blade ss prop on the motor and it didnt seem right so I put on a 17 pitch 3 blade ss prop that he included. He says it was his 'hole shot' prop.
I have only been out a few times on the boat and would like to clarify some things before I overrev/overwork this motor.
With the 24 pitch prop I drive it the following way:
Trim down all the way, wot
the bow comes up and does not plane for a long time(seemingly, could actually be short, I have nothing to compare this with)
before the boat will get on plane, the rpms will rise rapidly at a point and you can hear the motor sound different like there's no load on it
At this point, I throttle down a bit to lower the bow and then throttle back up and it will sometimes get on plane, if not I trim up a tad to give it more push (attempting to get the prop parallel with the water surface)
Once on plane, everything is good and I trim up little by little until I get to where it doesn't want to pick up speed anymore. My speedo doesn't work currently, I tried blowing air into the hose and the speedo needle moved, blew air the other way and air came out of the pitot hole on the outboard fine. Another topic later. So, I don't know my speed but I try to cruise it at 5500 rpm.
I switched to the 17 pitch prop last night, started with trim down at wot and the boat went NOWHERE. It just seemed to bog down. Stayed at 1500-2000 rpm until I could pick up enough speed to get in the powerband of the motor. I tried trimming up a bit to get the prop parallel with the water surface but then I'd get the rapid rpm rise again at 3500 rpm with bow up high. I was testing this on a fairly small lake so I didn't get to a good cruising speed/rpm.
What am I doing wrong? Do I need to move my motor up/down a notch on the transom bracket? It is currently at the 2nd hole from the top. Start with trim at a different level?
