Have 1981 J50BELCIC. Have now tried 3 props.
Was a restore job I did on a 1981 Starcraft SS161 (16 foot)
After engine was looked at and repaired. Started with damaged 12 1/4 X 15 with converging ring. Do not remember my RPMS I was getting. But did not seem right, had to cut back on throttle at high end,, did not sound right and would cut off alittle. Suspected was due to damage on prop
Switched to 11 3/4 X 17 pitch with convering ring. Was able to go full throttle with no issues or cutting out. But could only get 4500 RPMs at engine rated for 5000. This was spare which came with boat. But had no damage so thought I would try it out. The converging ring did end up breaking and got all kinds of issues after this.
Got new prop Turning point 12 1/4 X 15 pitch. Tried it out today. Boat comes up great on plane, At first looked like it was going to hit 5000 rpm. but then bogged down and settled out at 4000 RPM.. I notice it only has a small end extending out at the end, I assumed replaced the converging ring from the older props.. It acted like at high rpm was getting alot of cavitation (which I got on my 17 pitch when the converging ring broke) To be honest, the small extension out is no where near the protrusion of the converging ring of my old props. so I figured I would test this problem.
Switched back to the old damaged 15. Again got 4700 RPM. but at high end.. had to cut back as before. I suspect the damage to the prop is causing me issues.
My question is, I am sure with a 15 pitch I can get 5000 out of it, which is where it should be. But I am looking at all the new ones, and it seems they all just have this small outer protrusion to prevent the exhaust from getting sucked into low pressure area.. casing cavitation problems. Is this the problem I am having or is it something else..
