carltonwebb
- Jun 24, 2013
- 7
If anyone has any suggestions on a prop. I have a really wide lowe 14 foot flat bottom jon boat. Its older and someone painted over the decals so I cannot tell you the exact model number but the rails are 5 ft apart side to side. I will have to take the prop back off to find the current size/pitch but it matches the rest of lower section of motor so I am going to assume its the original one.
In reverse & idle, the motor revs up nice and high. In forward, it moves the boat but not easily by any means. I can see where the throttle linkage is for the piece under the flywheel and it is full stroke as well as I took the rod and tried to give more and could not get anymore. It just seems to be that much load. I also adjusted the manual tilt some (one hole at a time) but did not help any. It will get me through this week and then I can address this. I had a yamaha mariner 15 hp and it would move the boat a little better but I wanted a little more so when the Yamaha died, I got the 25 hp johnson.
This week we are running it in the tidal creek so sometimes we are going against the tide but even with the current it does not really pick up any rpm. This was me in the boat and two batteries today. The motor had good compression when i bought, all new fuel system to the carb and recently cleaned carb, New points/plugs and one new coil.
I was reading some previous posts for johnson and props and saw someone mention that both plugs only fire at certain times? Can anyone elaborate on that a little more?
I am also ignorant as to the proper way to set the tilt (?). Its manual tiller so I have tried it in a couple different holes with no real improvement.
Thanks in advance for all advice.
