Hey guys, I tried to research as much as I could but I think I need some input.
I recently put a 'new to me' 1976 Johnson 135 on my 18' Fiberglass runabout fishing boat. I took it out for its initial test and am having some problems. The motor idles great and runs well up till 12mph then it revs ways up and slows right down. I know this sounds like a spun hub, but the part that confuses me is that the prop is still spinning and kicks up a small rooster tail when this happens. If I bring it back to idle, then accelerate again it will move, but if I just lay off he throttle a little it keeps spinning. Also, i have to keep the motor trimmed all he way down, or this happens as soon as i hit the throttle.
So my question is, is my motor mounted too high causing ventilation? Or do i have a spun hub?
Thanks a lot guys.
Thanks a lot guys.
