Store Links Mobile - Shop Now
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 1 PM MST on 12/16/2017. The estimated amount of downtime is 3 hours. Thanks for being a part of the iBoats community!
See more
See less
What prop is this really
  • What prop is this really
    Part number on prop is 48-73132-10.
    One site shows: 15 DEGREE PROGRESSIVE PITCH -- Used on Mercury outboards, 35 HP through 140 HP. Usually have a 3 inch progressive pitch. Stainless steel and aluminum propellers. Doesn't mention diameter.
    Is currently on a 1999 40HP Force (pushing 20 ft pontoon). Might be slipping and if so need to replace.
    Re: What prop is this really
    Pitch is expressed in inches. Usually the number at the end is the pitch 10 Might be for a pontoon.
    Usually slip is the difference between theoretical speed and actual speed. Expressed in a %.ie.10 % slip.
    The prop losing grip is ventilation The prop becomes air fouled.
    If the prop is defective with a bad hub its called a spun hub. Ventilation and a spun hub seem the same
    but ventilation may happen at at different speeds or triggered by waves,while a spun hub usually happens at roughly the same power range.You can check the hub by putting a water proof line across the hub and doing a test run.Line will be broken if hub is bad..
    If a smallish prop probably a new prop is more cost affective.
    Pretty sure the 99 Force uses a Merc prop and has a Merc leg.
