Hi guys. Long time lurker, first time poster. I'm heading to Canada in the middle of June and want to purchase a new prop for my motor to either replace the stock one or as a back-up. The prop that is on the motor now is a 9 3/4 x 10 1/2F. The boat is a 14 foot Alumacraft V-14, a 68 inch beam Aluminum V-Bottom utility type boat. When I ran the boat (I just got it set up) there was plenty of speed with the following loading. Rear of boat, 29 series trolling battery, Endura 50#thrust Trolling motor, 3 gallons of gas, and my portly 240# of weight. In the front seat was my 100# grandson. I could not run the boat a WOT because of severe porpoising and it raised the front end significantly to get on plane and was slow to plane out. After it planed out the speed was impressive, even though I couldn't give it full power due to the porpoising issue. I'm looking for not only prop suggestions but any other advice on the issues stated. Thanks for any possible help with this. (Note: the motor has no tach or power trim. Test run was done with the motor angle trim pin in the second hole from the most lower position.) Please advise if more information is needed to help me find some answers. Again, Thank You.
